Stickers !
Jshodgson
Stickers !
Unread post by Jshodgson »
How do you remove old stickers from the boot of your car (external). I have some particularly old ones. :?:
Thanks, James
Had (Saxo VTR 1999 (T) LPG converted - do not ask!!!)
Had (Xantia LX TD 1995 (M) 144,000 miles)
Had (Xantia TD Estate (N) 147,000 miles !)
NOW GOT Picasso 2.0HDi (02) 96,000 miles
fivelighters
Re: Stickers !
Unread post by fivelighters »
Jshodgson wrote:How do you remove old stickers from the boot of your car (external). I have some particularly old ones. :?:
Thanks, James
:roll: :roll: Mmmm i would use a hair dryer then t cut then polish :wink: :wink:
x 1240
Unread post by Peter.N. »
I would second with the hair dryer idea. You can get some 'label remover' aerosol spray from TV/electrical wholesalers (if there are any left) try CPC on the net.
oscarloco
Unread post by oscarloco »
Once you managed to remove the sticker, you will end up with some stuborn glue. You can remove it safely using oil (baby, cooking, etc) and it won't harm the paint :wink:
Oscar Lopez
'94 ZX 2.0 8v petrol (restoration to its former glory on its way after being neglected by stupid Ex)
wilkobob
Unread post by wilkobob »
To remove sign writing from an old van I just used a kettle of hot water, makes the sticker go soft and peels off easily. Used t-cut to remove any stubborn marks, and this worked a treat. This method also worked for me to remove some go faster stripes from some bx doors a year or 2 ago, and they would have been there some time.
Clogzz
x 40
Unread post by Clogzz »
Work WD40 into the glue from the edge of the sticker, and it will slowly dissolve.
Peel off what you can, and keep wetting the glue with WD40 and wipe with tissues.
When all the glue is gone, wash the remaining WD40 off with window spray cleaner.
Jshodgson
I did the hair dryer and it worked. I then used vegetable oil and that shifted some glue...what it did do really well though was bring the silver trim at the top of the bumper up a treat!!!
I T-cut the rest off.
Many thanks. :D
