Xantia leather electric seats
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
hi all..
I am thinking of fitting a leather interior to my 1999 Hatch. How easy do you think it will be?
Presumably, I need to add the heated seat buttons, (although I am not too fussed with this).
I guess I need get a decent + feed to the motors under the seat.
Do i need a few relays to run from the seat switches? could i fit these under the seat to save a load more wiring running around the car?
I am thinking of offering £100 for the whole lot, in ok condition... (includes a bit of walnut) ?
John
PowerLee
Unread post by PowerLee »
Hi
You might already find the loom there for the electric seats & seat heaters.
PSA Peugeot / Citroen normally only use one cabin loom on the newer cars, It saves money having a few spare unused plugs then having a load of different looms made up :wink:
Have a look under the seats on in that aera hidden under trim for some plugs just floating around not connected to anything :wink:
I warn you now if they are heated seats make sure you check the heater works before you fit them, Its far easier to fix the seat heater BEFORE the seat is fitted to the car :wink:
Kitch
Unread post by Kitch »
We fitted some to a mates Activa....fairly easy. Just get a good supply to the motors and you'll be fine. The decent later style ones used in the Activas are the ones to go for....the VSX spec is very flat and un supportive IMO.
1991 Citroen BX 16valve
1998 Citroen Xsara 1.9TD SX
1993 Peugeot 106 XSi
1995 TVR Chimaera 400
f00lzz
Unread post by f00lzz »
Don't know about the activa seats but the Exclusive 'series 1' leather seats are preferable to the 'series 2' seats albeit minus the airbags, but at least you can 'boost' the squab sides to improve support.
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
Barbarian
Unread post by Barbarian »
where do you find whole leather interiors for xantias ? Id pay £100 for that!
joelataxi
Unread post by joelataxi »
a set went at the weekend on ebay £102.00
jgra1
(Donor 2021)
x 36
ok ok the interior is mainly leather, Barbarian!
Barbarian
eh
Barbarian
can you not buy the walnut trim for the dash online somewhere knew ? I know you can buy all that sort of stuff many other cars
jgra1
(Donor 2021)
x 36
sorry barbarian :) i got wrong end of stick
If (they) want £150 for everything interior wise i will let you all know.. I dont really want to pay that much ;(
