Flat Xantia
keefy21m
Flat Xantia
Unread post by keefy21m »
Hi everyone, I have a 1996 Xantia 1.9d with 110,000 on the clock which I have had since last October. When I am doing say 55 mph on the motorway and put my foot down to go faster there is a flat spot and the car actually goes slower, however if I back off from this and press the pedal down slowly it gradually picks up speed and all is well,also happens between 60 and 70. What could be causing these flat spots? Also the fuel consumption is always only 38-40 mpg even if i drive it like a vicar, surely it should be more than this?, this is my 1st Xantia so not sure what to expect.
It is a bit lumpy on first start up with some blue smoke but uses no oil at all between oil changes but once warmed up goes ok, just the flat spots.
Any help much appreciated.
Keith
Dave Burns
Unread post by Dave Burns »
Could be a blocked fuel filter, those are typical symptoms.
Dave
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Mmm agreed
The pump cannot get enough fuel through to satisfy the demand of the pump when your toe has gone flat to the flour...
How ever, when pressing down slowly, theres not as larger demand for a greater supply of fuel and can cope with it..
Check it out and replace filter first.
Regards
citroenxm
A very sad...
1994 XM 2.1 d auto
keefy21m
Flat Xantia
Thanks for the replies, I did replace all the filters in Jan including the fuel filter but it is still the same, Any other thoughts?
Cheers
Keith
Kitch
Unread post by Kitch »
Air leak in the fuel?? Although that could cause worse starting problems.
Or a duff turbo?
1991 Citroen BX 16valve
1998 Citroen Xsara 1.9TD SX
1993 Peugeot 106 XSi
1995 TVR Chimaera 400
PowerLee
Unread post by PowerLee »
Original poster said it was a straight 1.9 D :wink:
Kitch
I retract my previous statement!
Not much it can be really.....air and fuel filters aside....diesel pump timing perhaps if its 1 tooth out?
Or perhaps injectors need cleaning out?
citroenxm
Fallen Hero
x 70
Hi
If timing is 1 tooth out it will absolutly NOT run at all!!
Diesel timing has to be soo close to spot on to run!
Regards
citroenxm
A very sad...
1994 XM 2.1 d auto
x 1240
Unread post by Peter.N. »
What are you doing on here?
f00lzz
Unread post by f00lzz »
Can the advance and retard be causing this fault?
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
x 1240
Unlikley. If its over advanced it will knock, if its retarded it will be difficult to start, low power and very quiet.
f00lzz
Thanks Peter...I ask because since rebuilding my own head after cambelt failure I feel sure it is noiser (quite a harsh 'cackle') any advise?
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
citroenxm
Fallen Hero
x 70
Peter.N. wrote:What are you doing on here?
Hi Peter,
Have you a problem?? Do I give out incorrect advice?? Remember, the Peugeot engine is the same as citroen so any knowleadge can be shared here... We have purchased a 309 for my lady to drive around in..
Regards
citroenxm
A very sad...
1994 XM 2.1 d auto
x 1240
Hi citroen XM
I wasn't being at all critical, I was just surprised to see you! I,m sorry if I gave you that impression.
Peter.
citroenxm
Fallen Hero
x 70
Hi Peter.
Ah right, sorry. It came to me incorectly. If its XUD, XUDt or HDI powered then I'll have a go...
If citroen then of course!!
New member, J reg 309 1992, 142k FSH, excellent engine, couple of jobs needed. My lady is REALLY pleased with it..
Regards
citroenxm
A very sad...
1994 XM 2.1 d auto
