Hi I'm new ;)
td2k
Hi I'm new ;)
Unread post by td2k »
Just bought a M plate Xantia TD LX as my daily drive, very happy with it. Last Citroen I had was an XM about 10 years ago, I had forgotten how smooth the ride is....
There are a couple of issues with the car, its difficult to get into 1st/2nd gear (I'm assuming just the gearbox oil needs replacing), and the rear ride hight adjuster is a bit sticky, so will be sorting these out shortly :)
I am after a couple of "missing" bits, the main one is a rear parcel shelf (mines missing) and a IR central locking plip.
Many Thanks,
AB
AndersDK
Unread post by AndersDK »
Welcome on board -
Dont think its a matter of replacing gear oil. These oils tends to last "forever". Instead check the gear oil level - and the pedal height. Citroen clutch pedals usually must have some 140mm clearance over any carpetting on the floor. That is quite higher than the other 2 pedals.
Anders (DK) - '90 BX16Image
jeremy
Unread post by jeremy »
I agree with Anders. The clutch pedal should break a bit above the floor - for some reason all professionals changing clutches seem to regard adjustment of the clutch cable as a job they must never do!
jeremy
Saw Doc Fan
Unread post by Saw Doc Fan »
Regarding your parcel shelf, there was one on ebay the other day, just search for xantia parcel shelf, i'm sure there was quite a few days left on it.
'94 M Reg Xantia 1.9 TD LX...70,000 miles, had it 2 years now and still LOVE it.
What a day,Oh what a day...
KevMayer
Unread post by KevMayer »
I've got a spare parcel shelf in my garage.
You can have it if you can arrange to pick it up.
Cheers,
Kev
Cheers, Kev
JohnCKL
Unread post by JohnCKL »
I think clutch pedal is 150mm +- 10mm.
Xantia 1.9TD 1996
rabenson
Unread post by rabenson »
Always had slight problem engaging 1st on my zx - found that slipping it into 2nd then into 1st helped.
Ron
2007 C6 2,7 HDI exclusive 95k
2004 C5 VTR HDI 103k
td2k
Thanks for the replies :D Will have a look at the clutch adjustment over the weekend. The clutch pedal is only just higher than the break pedal....
Kev, where abouts are you?
KevMayer
td2k..... sorry for the late reply.
I'm near Cannock.
Cheers, Kev
