hi all, i am replacing both bushes on the suspension arm of a 405. I normally get someone to do this for me but have stupidly tried myself. I am confident I can remove the rear bush. But have began by tackling the front one. It is three metal cylinders with rubber sandwiched between them.
I have got rid of the inner 2 cylinders with some hard work. Now the hard one.. I am hacksawing thru sidewalls.. but there isnt much to hit after i have done that.. any tips? getting dispondant..
John
Suspension Arm bush replacement
jgra1
- (Donor 2021)
- x 36
stevieb
I did things two ways on my old 405. At first I just bought the bushes - the bushes had marks for where to align with the old arms. Very good, but a pain to align.
Later, the front bushes needed doing, and the easiest option was to replace the whole arm (with bushes pre-fitted). The rears were pre-mounted at a similar angle to the original replacements I added. To me this confirmed that they are mounted based on the stress that will be applied under normal loads.
A car that works a lot over heavy ground may fall under a different set of cuidelines, though I imagine all UK spec vehicles are designed for "good surface" - obviously Pug/Citroen engineers don't visit the UK on their tour of potential markets....
