casso wrote:Thanks for replies.
Had another look in daylight. The plastic rod has come apart leaving one end attached to the brake pedal (with the spring) and the end that goes into the brake valve had detached and fallen on the floor. I've put it back together and it's working as before but I can't figure how it happened and more importantly how to stop it happening again.
Should the rod just pull apart or should it be more secure ?
Did you find the two split rings that hold it together ? It shouldn't be able to just fall apart. There are the two split rings that stop the end falling off as you describe, then there is a sleeve that pushes up against the split rings to stop them coming out. The sleeve is held in place by being pushed against the shoulder of the brake pedal arm.
The only way it could fall in half would be if it moved away from the arm and the sleeve slid uphill - which shouldn't be possible because every time you push the pedal you're pressing that sleeve back over the split rings... so I'm a bit mystified...
I can confirm however that the handbrake is quite efficient when pulled very hard by a frightened driver !
Yeah it is pretty good. All Citroens have the handbrake on the front, and in the case of the Xantia it operates on the main pads as well.
On my last MOT test the handbrake scored more than the minimum requirement for the front footbrake! (And the footbrake scored 2.8 times the minimum)
Just for kicks I've tried the handbrake going down a (deserted) fairly steep windy hill and although it took at least twice the distance of the footbrake, it did stop me, which impressed me...
Regards,
Simon
