Xantia window relay
Mads
Xantia window relay
The electric windows on my Xantia has developed a periodic fault; Occasionally both the left and right window refuse to move. Sometimes you can resurrect them by turning off and on the ignition. Am I right in assume this will probably be a relay problem, and that I most possibly need to replace the control box in the front door ? Can the box be repaired?
Mads
C3 1.4HDi, 2003, 85000km
Xantia 2.0 16v Estate, 1997, 195000km
AndersDK
Control box would only be in drivers door and only affect driver's window. Further the controlbox is only fitted on models equipped with one-touch control.
As your problem is found on both sides windows - the problem should be found in the common circuit for both : fuse, relay, earth point and power feed.
Fuses are known to fail intermittently and still look OK. Relays are known to become partly detached in their sockets - simple cure.
Anders (DK) - '90 BX16Image
Mads
BonceChops
It is quite a simple mod to add the control unit into the passenger door. All the required mouting holes are there waiting. I modded my last Xantia and will be doing this one.AndersDK wrote:Control box would only be in drivers door and only affect driver's window.
I don't have the drawings with me at the moment but if you have a Haynes they are in it. I am guessing at a relay that feeds +12v supply to the drivers and passenger door may be at fault.
As a quick test when it stops working can you use the passenger door switch still or not?
Now Citrtoenless
Now Citrtoenless
Mads
Non of the contacts work when it has it's moods. I'll have a look at the wiring diagram in my Haynes manual this evening and see if I can find a likely caurse. I presume the relay you suggest will be a good candidate if it feeds both windows.
Mads
