Xantia MOT
rossnunn
Xantia MOT
Unread post by rossnunn »
Just done a quick check over before it goes in, could do with front discs & pads no woirres there. I noticed that one of the rear bump stops has torn open, would this be a failure? seems stupid to send it in to fail on something so small.
Also can I get the bump stops from ECP or GSF if so does anyone know the part/item number & rough cost or is it a dealer job? :(
Village
Unread post by Village »
just had a quick tinternet search and came up with :
http://www.motuk.co.uk/manual_240.htm
it appears that a missing bump stop does not constitute a fail, so I'd have thought that a broken one should be ok.
Also had a quick look at the GSF catalogue but couldn't see bump stops listed..
Pete
French car free zone....
andmcit
x 30
Unread post by andmcit »
Thing is, I know this sounds stupid, if it's actually there and damaged it's a sure failure, but if it's missing, you'd be OK!! Been here before with hazard indicators and fog lights on old Cit's!!
I've never fully understood the MOT mentality!
Andrew
rossnunn
yeh thats what I was thinking & it seems so stupid to fail on something so simple.
