Off to the Breakers will any XUD sump suffice? Dont want to make a mistake have you seen all those bolts
ZX 1.9d Replacement Sump Help
citroenbx
Discovered an Oil leak on my 1992 1.9d ZX to coming from the smallest of fractures on the sump...I've heard of sumps wearing out but never had a car where this has happened
Thanks in advance.
Life feels good just as you complete No4 Glow Plug on a ZX-TD
Stewart(oily)
- x 35
PowerLee
AndersDK
Yes I've seen all those bolts that needs to come off
Note that there are in fact 2 main types of sumps around :
Earlier type with a slightly raised edge on the middle of the seal surface to help compress the good old style "paper" seal.
Recent type designed the opposite - i.e. sort of slightly hollow to hold a bit more sealant paste.
You can use either - if you're using correct sealing method.
At the same time do a major maintenance to the oil fume and filler hoses - as if the sump pressurises it will strain the seal.
Clean every thing well (incl. bolts) before refitting.
On re-assembly tighten the sump bolts evenly in cross pattern. Do not torque the bolts as they may rip the thread - or snap.
Anders (DK) - '90 BX16Image
