steve.cafc wrote:Hello Kawalski,
You wont believe this but someone's done a botch job with my rubber tubing !
The smaller tube that's supposed to go into a T-Piece actually goes straight to the cold start device !
I can see the two green electrovalves minus the T-Piece and tubing, I'll get some tubing from work tomorrow.
Is there anyway I can test the electrovalves, in case they've been disconnected for a reason ?
Many Thanx
I know on my Xantia, I can hear the valves operate, its a slight clicking noise I hear. I'm not sure whether the noise is mechanical from the valves themselves or the popping noise you get when you release the vacuum to atmosphere. The valves do fail its fairly common, the coils on them go open circuit and they stop working, you can check their resistance with a multi-meter, if its open circuit they're broken.
If the vacuum hose connects direct to the cold start device and has no leaks in it, what I said about it being a fault with the EGR hose can't really apply since it isn't connected. If this hose is connected all of the time your engine will idle at the slightly higher cold idle speed. On my car, one electrovalve / plug is blue (idle speed) the other from memory is green and does the EGR.
As interesting as this little wild goose chase has been, I don't think it can be whats causing you to lose your vacuum assistance to your brakes since the hoses aren't connected to any valves. The electrovalves operate in a seemingly random way when you press the accelarator, the fact that you said tapping the throttle made the servo came back made me think that it was these valves.
I'm not really sure how to test the master cylinder (since I haven't got one on my Xantias), but if you pull the vacuum hose off the pump and stick your finger over the pump outlet, you should feel good suction, if there is good suction the problem is not with the vacuum pump.
