How to replace C5 rear pads and discs?
bencowell
The car is a 2.0 HDI 110 (2002 model)
Firstly, is it an easy job? I only have pads, discs and 4 caliper bolts (on advice from Cit).
Any hints and tips? Do you need a special tool to rewind the rear calipers, or will a square section bar or a G clamp do?
Thanks in advance.
Ben
Thanks in advance.
Ben
AndersDK
JAY61076
bencowell
ebod
Bencowell, if they owt like my 2002 xsara hdi-110 , its a piece of p*ss.
Mine were Bosch calipers which just had a pair of 17mm AF head screws on the back. Just undo the screws, take off the caliper plates with the pads , and get a thick blade screwdriver to wind back the caliper piston.
Maybe I exchange knowledge for a quick test of that chip of yours
( I'm at Hollingworth Lake just inside the east lancs border )
Sir Clive
In theory, undo pad retaining bolt, pull off cover, remove pads. Push pistons back, pop new pads in, reassemble.
In practice.... corrosion occurs between the back of the alloy caliper and the steel mounting plate, and this forces the caliper out of line. The mounting bolts also corrode into the caliper. This can make the job quite difficult, it took me ages to get the bolts freed up, so I could take the calipers off, clean them, and apply a coat of copaslip to stop it happening again. and yes, you *will* need those new bolts! Also worth giving them a good smear of copaslip too.
Now I've done all this, I hope the next time I have to change the back pads it will be a failry painless procedure
bencowell
Sir Clive
Take out the pad retaining bolt and remove pads. Then REPLACE the pad retaining bolt and tighten nut. You can then take out the through bolts without the caliper coming in half.
If you go to these people: http://www.brakeparts.co.uk/
you can get new pad bolt/dustshield kits quite cheaply. You'll find the originals do take quite a bashing!
HTH
HTH
bencowell
bencowell
I asked the dealer for a printout of the exploded diagram from the parts computer.
http://www.bencowell.pwp.blueyonder.co.uk/c5rear.jpg
Hope this helps anyone interested.
Ben
p.s. Does anybody know the torque to be applied to the bolts?[/url]
Ben
AndersDK
bencowell
Cheers AndersDK, I've changed it to a url.
This is the diagram from the Bendix pads, it shows how the springs fit.
http://www.bencowell.pwp.blueyonder.co.uk/c5brake.jpg
Sorry, this one is a 600k file. Had to scan at higher resolution in order to see it!
Ben
Ben
Kowalski
and
