Hi folks,
As a new boy to xantias & an electrician by trade, I have just had my TD fail its MoT with an excessively rough rear wheel bearing. What are these like to change, as the Haynes book of lies says that you have to replace the whole hub. Any hints or tips welcomed.
Xantia Rear wheel bearings
AndersDK
Yes the bol is in fact correct for once.
The rear hubs are repalced as complete assemblies. Its not worth the hassles trying to reduce parts price replacing individual bearings in the hub.
There are 2 kinds of hubs around : for ABS with a toothed "cam" - or non ABS.
And they come pr side.
Remember to get the inner seal slider cup - as its not contained in the hub kit :
(original Citroen part only)
3726.14 - BEARING CUP (approx £1)
Job best done using a knife edge puller to get behind the inner bearing race on the axle stub. But I managed to do it using a sharp edged chisel hammering behind the race.
Anders (DK) - '90 BX16Image
Kowalski
I've got bearing noise at the moment on my car, but no roughness or not enough so I can tell which bearing is making noise. GSF lists 4 different hubs for the Xantia, early ABS, early non ABS, later ABS and later non ABS. Prices are around £40 for the rear hub bearing, I'm hoping its a front because they're less than half the price (although much more fun to replace).AndersDK wrote:Yes the bol is in fact correct for once.
bxbodger
These are very much the same as the BX one to change. Mine came off with the old style RWD hub puller I last used on a Marina. Because the hub and bearing come as one piece it does make the job easier, although the bit costs more money.
To get the inner race off the stub axle I used a grinder, and cut into it enough to split it.Job best done using a knife edge puller to get behind the inner bearing race on the axle stub. But I managed to do it using a sharp edged chisel hammering behind the race.
AndersDK
Andye
