xantia heater problem
Post Reply
baffsfishing
My Cars:
Post by baffsfishing »
hi folks
spring is in the air so i decided to give my xantia i going over,oil change.air filter change,and i got this spray for cleaning out the aircon you let it off in the car with the aircon on recycle and leave it for 10 mins
anyway since i did these i now cant get any air out of the wind screen vents it seems to be stuck on full face blowing?the only other thing i did was to put my radio back in it was needing decoded any ideas folks?
could the spray have done something? or could i have knocked something when i replaced the radio
cheers in advance
roy
My Cars:
x 92
Post by citronut »
what car is it ,it could be your pollen filter is cloged up
regards malcolm
baffsfishing
My Cars:
hi citronut
its a t reg xantia facelift with air con
cheers roy
KennyW
My Cars: Current Citroen's
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
Xantia 2.0 90hp estate
Xantia 1.9 TD estate
x 132
Post by KennyW »
Hi Baffsfishing,
If it's not the pollen filter it could be one of the cables which operate the flaps from the heater control panel just below your radio.
I've got a similair problem after having to change the matrix :cry:
One hell of a job but not difficult. Due to look at same in better weather awaiting spring!!!!!!
regards
KennyW
C5 x7 2.0 HDi 160 hp Estate exclusive, the newbie
C3 1.4 petrol (SWMBO)
mezuk04
My Cars:
Post by mezuk04 »
Just to avoid a few more posts.
The pollen filter is located in the passenger footwell, up above the carpet. It is housed in a container with a lid that either slides off or in place with 3 screws.
Volkswagen Golf 59' 1.6TD S :(
baffsfishing
My Cars:
hi kenny
tried it with the filter out still not working,was going to try and take the glove compartment out to see if i could see anything behind it but i could only find about 5 scews in the top of the compartment i took these out but it wouldnt pull out do you know if there are other screws holding it in that am not seeing? i dont want to pull it to hard and set the air bag off lol
cheers
roy
KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
x 132
Post by KennyW »
Hi Roy,
Yes ,there are other screws hidden underneath the material in the glove compartment.
If you are trying to access the pollen filter there is no need to remove the glove compartment as mezuk04 says its above the carpet in the passenger footwell and secured either by screws or tab.
Have you checked the cables which are used to operate the heating panel one of these has probably come loose.
regards
Kenny
baffsfishing
My Cars:
hi all
it was the cables i was looking for when i tried to remove the glove compartment,if there not behind there could someone please tell me where i can locate them
cheers roy
KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
x 132
Post by KennyW »
Hi Roy,
The cables are fitted to the slide controls for the temp control, window demister, face and floor vents.This located in the cnetre of the dash below the radio but if you wish to see where they go in the heating system would require you to remove dash!!!!!!!!.
There is a thread which Clogzz sent to myself showing the cables in picture form
Regards
Kenny.
KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
x 132
Cables
Post by KennyW »
Hi Roy,
Look at this thread and it pic's this should help
http://www.frenchcarforum.co.uk/forum/v ... hp?t=17951
I knew there was thread somewhere on the forum.
Once again thanks to Clogzzs.
Regards
Kenny
baffsfishing
My Cars:
hi kenny
thanks for the pics, god this looks complicated i might just have to get the missus to blow hot air on the screen when it mists up lol,i will have a go at it tommorrow and let you know how i get on.
cheers roy
Post Reply
