clock for 306 (with temp)
Harlequin
x 24
Unread post by Harlequin »
are the wires / sensors built into all 306`s to display the temp on a compatable display?
rossd
Unread post by rossd »
Easy one this and one I can answer as I've done it!
The loom is present as far as the passenger door. What you will need is a door loom from a model with the temp sensor in the wing mirror and the sensor itself. Simply plug all these into your car, plug in the clock\temp display and off you go!
I did this on my old DTurbo, worked a treat! :D
2003 Xsara HDi 110 - Commuting Hack
http://www.rossy.org.uk/ - 205 Track car progress
