Sorry to bring this up again - I have checked the reistances via the multi pin plug with info from the forum and it appears all sensors are ok as reading over 1000 for each of the circuits - is there any other electrical fault that i can check for before I start messing about with the system - can I confirm the ABS light only refers to the ABS system and isnt anything to do with the pads etc etc -
still the light refuses to go out and the elusive MOT cert is no nearer and Haynes doesnt really give any help at all - i have checked all fuses.
As a recap the ABS light came on the night before the mot test at the same time the hand brake cable failed (what a night ) - is it possible this has broken a wire somewhere - if it is why do the sensors show a reasonable reading on the multi meter ?
Happy days - new tyres, new spheres, sense of humour - just cant get the ****** light to go out lol
ABS mot - again
jeremy
- x 3
These links may help
http://www.bba-reman.com/index.htm
http://www.carelect.demon.co.uk/
Some Xantia ECU's are prone to problems which some consider are due to the use of a flexible plastic circuit.
jeremy
jeremy
jeremy
AndersDK
1) The pads wear warnings have nothing to do with ABS light. These are separate circuits and warnings.
2) You have read out "over" 1000 on each sensor ? That does not sound right to me. The reading should be close to 1000 ohms on each sensor - not simply "over".
Meaning readings between some 900 - 1200 ohms is correct. The resistance you are checking is the sensor cabling and the coiled thin wire in the sensor itself - As the sensor is a wounded magnetic coil sensor. This can not be super accurate - hence the allowance for deviation in readings.
I have a feeling you may have overlooked a couple of bad sensors (or cablings) using your approach. Because "over" 1000 can very well be interpreted as a disrupted sensor.
Anders (DK) - '90 BX16Image
Ross
Ross
- x 94
have you checked all of the fuses,as some one i know had a BX with ABS light on all the time,it had blowen fuse 14 which is only for ABS system,then a few months later i noticed the light was back on so i asked him if he has had to stamp on his brakes recently he said he had,fuse 14 had gone pop again,so we put it down to something in the ABS unit causeing a dead short when it came into play hence blowing the fuse
regards malcolm
regards malcolm
PowerLee
