New Radio Fitted
Nomad
New Radio Fitted
Unread post by Nomad »
Hi
So when did radio connectors become standard?, or was i just lucky?
I brought a cheap radio € 80 for my Xantia (it plays MP3 via CD, SD Mem card or USB Mem Stick. I all so went out and bought a load of spade connectors and some cable (just to be prepared)
The new radio had two big connector blocks on it so i thought i would be there ages tracing the feeds and the speaker cables and getting them connected.
But the connectors on the cable from the car just clipped in to the new radio, and every thing works fine :) The only thing that wont connect is the aerial cable as it has a female connector and the radio a male one, so i am off out to buy an adaptor for it now.
It has been about 12 years since i fitted a radio in a car and it was never that easy.
Also had to fit the new face plate and heater fascia surround, i got an original Citroen one from a car in the scrap yard (the one with the opening & closing panel that hides the radio) for € 2.
OK the steering controls do not work , but i knew that would not, but for some reason i can not figure out, the new radio comes with a IR remote control :? i cant see the point of that really.
The whole job took about 40 mins
Tony
Xantia 1.8i 8v Presige 1995 Left Hand Drive, 5 door hatchback
jeremy
x 3
Unread post by jeremy »
Not as much fun when they plug straight in is it!
Have fun reading the instructions - I fitted something similar in my BX last year and I'm still inding new bits that it'll do.
Whilst I know that remote units exist I've never used one but do wonder if it may be quite useful and give simple access to some of the more useful functionson the radio. Whilst you can't get the steering column controls to work you may be able to fix the remote somewhere where its convenient - possibly even the wheel boss!
jeremy
dnsey
x 19
Unread post by dnsey »
With a bit of time and ingenuity, you could even wire the remote control direct to the steering wheel buttons.
Nomad
Sod that, it sounds like too much work. :)
