Brake spring kit - Xantia
sbraud
Unread post by sbraud »
Hi Guys,
Can anyone recommend an online merchant who might stock complete Xantia F Brake calliper spring fixing kit… you know, calliper pin, lock pin, metal glide and spring.
Cheers
Steve
95 Xantia 20/16v 155 bhp VSX 210k
97 Saxo 1.1 SX 100k
03 S-Type Jag (sorry!)
``Only standing on the shoulders of giants - The more I know, the less I understand?? Ignorance is bliss! ''
AndersDK
Unread post by AndersDK »
There are 2 main types of brake caliper service kits around.
1 type contains new bits for fitting & securing brake pads doing a standard brakes service.
The other type would be a caliper repair or overhaul kit which contains the service bits you need if you dismantle the caliper for a major brakes service. Mainly rubber parts.
Both types are available from where you would ask for model & make specific car parts e.g GSF, Eurocarparts, Halfords, Citroen, your local trusted etc. etc.
Anders (DK) - '90 BX16Image
