306 XSI (8v)
KATY
306 XSI (8v)
Unread post by KATY »
Hi all...
I'm new here & in a lot of trouble I've broken "HER" beloved pug & promised to fix it.........
The question is can anybody tell me how to get the cam box cover off ? its a 306 2.0xsi with the early 8v XU series lump ?
After removing all the bolts, hoses etc I expected to be able to just lift it off but there is not enough room at the back for it to clear the servo! so at the moment i'm stuffed....
I Read through the manual & it suggested removing the lower left engine/gearbox mount so as to be able to move the lump to create enough space to be able to remove the servo unit.... am I to assume the same procedure is applied for the cam cover? if so thats what I will do but the logic seems daft & a lot of extra work.
Hopefully.....
KATY
pugxpert
Unread post by pugxpert »
put jack under engine and remove top engine mount you can then go down a bit and forward :wink:
EP6T petrol turbo nice engine in the 207 GT and the new mini....
KATY
306 XSI (8V)
CHEERS...
The bugger came off just as you explained
But now its all got a lot worse..........
Whilst tinkering I droped the oil & found it was quite milky (1st horror) so did a quick pressure test & it was S**t on 1 & 2 cyls (2nd horror).
I stripped the inlet manifold out & discovered the oil leak which I thought was coming from the cam box was in fact coming from the head gasket, (3rd horror)....
So I've deceided to strip it down & see what can be salvaged, repaired or replaced.
Regards
KATY
