Hi all, I have a good slightly used 1.8i Xantia clutch and am wondering if I can use it in my Xantia 1.9TD? I am 100% it will fit. Surely the 1.8 petrol is more powerful, are the torque figures going to be wildly different?
John
Clutch Question Xantia TD
Mandrake
- x 694
It depends on how you define "more powerful". The 1.8 petrol may have more horsepower near maximum revs, but less peak torque. In fact the 1.9TD has slightly more peak torque than even the 2.0i 8 valve petrol, and it's torque that matters for clutch ratings...
Regards,
Simon
Regards,
Simon
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
Kowalski
Re: Clutch Question Xantia TD
As Mandrake has said, the TD is more torquey, the figures aren't wildly different, the TD only has about 50% more peak torquejgra1 wrote:Hi all, I have a good slightly used 1.8i Xantia clutch and am wondering if I can use it in my Xantia 1.9TD? I am 100% it will fit. Surely the 1.8 petrol is more powerful, are the torque figures going to be wildly different?
John
AndersDK
Only about 50% more peak torque ... 8)Kowalski wrote:... the figures aren't wildly different, the TD only has about 50% more peak torque
John - I wouldnt bother experiment with this. The risc of getting a slipping clutch out of this job is simply too large.
Anders (DK) - '90 BX16Image
OnlineRichardW
- x 1463
jgra1
- (Donor 2021)
- x 36
- x 94
GSF list diferant part numbers for these clutches,and you can tell if you have a push or pull clutch by looking at the cable at the gear box end,if it a pull clutch the inner cable is atached to a fixed point and outer cable is atached to the fork lever,and if its a normal push type the inner cable is atached to the fork lever
regards malcolm
regards malcolm
jgra1
- (Donor 2021)
- x 36
update
Removed gearbox and clutch in 70 mins!! (getting too much practise at this)
well, the petrol 1.8i clutch housing is slightly smaller then TD so that made my decision for me.
re: push/pull
My Xantia was a pull type, but when i destroyed the gearbox in February, I put on the only spare I had, which was from a 1.8 TD 405. Gearbox is fine, works nicely, but there is no way of fitting the Xantia Pull extension on it, so I used 1.8 TD push clutch.
So, I Guess what I need now is a push type clutch for a 405 TD and that should be the end of it.. lowest price i am finding so far is around £50.. I just want the car off drive now..
re: push/pull
- x 94
thats fine but make sure its a quality clutch kit not one of the cheapy kits on the market,one of my customers insisted he supplied his own clutch kit once,when i fitted it to make it work i had to adjust it right to the end of the adjustment,also it should be the same clutch as in the BXs,GSFs 04 retail catalouge shows this kit there part No.t18932 at a cost of £75 squide
regards malcolm
regards malcolm
jgra1
- (Donor 2021)
- x 36
jgra1
- (Donor 2021)
- x 36
- x 94
AndersDK
jgra1
- (Donor 2021)
- x 36
jeremy
