Outside temperature gauge
Saw Doc Fan
Unread post by Saw Doc Fan »
Hi there
Hubbys just bought a 404 2.0 GLX estate, and the outside temperature gauge is just flashing 2 dashes, could anyone advise how to get this working???
'94 M Reg Xantia 1.9 TD LX...70,000 miles, had it 2 years now and still LOVE it.
What a day,Oh what a day...
Homer
x 16
Unread post by Homer »
The sensors are prone to failure. It will probably be located in the driver's door mirror.
PowerLee
Unread post by PowerLee »
Homer wrote:The sensors are prone to failure. It will probably be located in the driver's door mirror.
Its in the PASSENGER side door mirror, Look under the bottom edge for the little black raised blob, Thats the sensor, About £18 new from Peugeot :wink:
Homer
x 16
Just going by my Xantia which always gave a higher temp reading when the drivers side was facing the sun.
PowerLee
No idea where the Xantia one is loctaed, But im 100% sure the 406 one is in the passenger side mirror :wink:
fatbugger
Unread post by fatbugger »
Yes
I agree with Power Lee
Thats where mine was situated on my 406 GLX Passenger mirror underneath
Mike
2005 Peugeot 407 SW SE 1.6 HDI 110 BHP
1998 Peugeot 406 SX TD Deceased
1999 Xsara Sensation 1.9D Deceased
batwad
Unread post by batwad »
They can vary with age. On my old 306 it was in the passenger's door mirror; by the time my newer 306 was made they were putting them in the driver's door mirror.
As PowerLee says, look for the raised nubbin on the underside of one of the mirror's hinges. This is the sensor poking through a hole in an access panel which can be removed to get at the sensor. IIRC you will need to remove the whole mirror housing from the door to change the sensor.
Saw Doc Fan
Cheers everyone
the car is a 405 (not a 404) as i said in the 1st post... typo error, will do some investigating when the weather is a bit warmer.
Pugsulike
Unread post by Pugsulike »
I had same problem on my 1995 405 GTX. The temperature sensor is in the base of the passenger mirror.
I took the car to a Peugeot garage for another problem and mentioned the faulty temperature guage to see if the mechanics had any ideas. When I collected the car, they had repaired it (I hadn't asked them to) at a cost of around £70, which I objected to and they cancelled the charge!
They told me that the sensor was fine, it was a connection inside the passenger door that was causing the problem. Don't know if they just cleaned it up or had to replace parts. May be be a bit of a pain to take the door trim off though, if it's never been removed before.
fastandfurryous
x 4
I'd say the problem with the OP's car is more likely that the sensor has become disconnected, rather than gone wrong, and when the sensors fail, you usually get some rather odd readings on the temperature gauge (like 45C when it's clearly snowing outside!). However, unplug the sensor, and you then get 2 dashes rather than a temperature.
I'd check the plug in the door, and also the plug in the back of the display unit.
This is not a signature.
AndersDK
Unread post by AndersDK »
I'd defo check the cable in the rubber gaiter ...
Its such a common problem on recent cars as they are crammed with electronic gadges located in the doors which have their electric feeds all running the same route - and all strained each day you use the door ...
Anders (DK) - '90 BX16Image
jgra1
(Donor 2021)
x 36
xantia temp sensor
Unread post by jgra1 »
mine always over-reads..
It seems to be accurate when you start the car, then, even on a icy morning, it climbs to 10 or so, (without Rear Screen on or With)
must be a sensor then..?
Passenger door mirror is the location
John
