Why differant spheres?
RStacey
Unread post by RStacey »
Hi
Does anybody know why the front sphere specification for a 1.9D xantia is different from the TD? I have just "borrowed" the spheres from my daughters off the road 1.9TD and put them on my 1.9D until I can buy some new spheres - I was going to buy the correct spheres for the 1.9D, but the ride with the TD spheres appears fine and I am now unsure what to buy
Any thoughts welcomed
Richard
ps - thanks for a superb forum - If I have a Xantia problem I always look here first
1999 Xantia HDi Exclusive
2003 C5 HDi SX
1995 Xantia 1.9TD
1994 Xantia 1.9D
AndersDK
Unread post by AndersDK »
Supposed to be different i.e. harder damped for the faster TD model.
Be careful ! If you have been driving around for longish with flat spheres - anything replacing these may feel like a new life to your Xantia :wink:
Anders (DK) - '90 BX16Image
Mandrake
x 694
Unread post by Mandrake »
Yes,
The early (before 1996) 1.9D spheres give a softer ride because they have higher gas pressure and larger damper holes.
What happened was that in the early models of Xantia they started out with the lower powered models having softer ride, however the higher powered models (including 1.9TD) had a firmer ride and damping to handle the higher power and therefore higher likely dynamic forces on the car. (The softer springing of the 1.9D was just too soft for anything but leisurely driving, and didn't give very good handling)
From 1996 onwards all the models (except Activa) were standardised into using the same spheres with only the following variations: Hydractive2 vs non-Hydractive2, and for the rear spheres also Estate vs Hatchback.
So there are four versions of rear spheres and two versions of front spheres, that cover all models, post 1996, not counting the different diaphram materials.
This means that since 1996 the 1.9D and 1.9TD both get the same spheres anyway, which are equal in pressure to the old 1.9TD spheres.
So in summary - you can put 1.9TD spheres on a 1.9D with no problems - you will get a slightly firmer ride than original with better handling. The ride will be the same as a 1.9TD.
You should not put 1.9D spheres on a 1.9TD - you will get the soft ride of the 1.9D but you will also get the poorer handling, and together with the extra horsepower its not a good combination.
Regards,
Simon
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
RStacey
Thanks - that explains it perfectly - I've no idea what the original spheres felt like as the front spheres were deflated when I bought the car but I dont need it any softer so I'll stick with the TD spheres
2003 C5 HDi SX
1995 Xantia 1.9TD
1994 Xantia 1.9D
Mandrake
x 694
RStacey wrote:Thanks - that explains it perfectly - I've no idea what the original spheres felt like as the front spheres were deflated when I bought the car but I dont need it any softer so I'll stick with the TD spheres
Probably because they were almost "deflated" :)
The gas slowly leaks out of spheres over a period of years and the more that leaks out the stiffer the suspension gets, until finally its completely rigid. It's only because they ride so soft in the first place that people don't notice until they're nearly stuffed...
Regards,
Simon
Simon
1978 CX 2400
