This Multipoint used a single entry fuel rail with no return, but in the breakers I found they did one that had a return pipe, so I pulled that & put it in mine.
Now this fuel rail has, what I believe to be, a vacuume operated valve that opens the return part of the rail.
On the car I took it off it had a valve on the side of the inlet manifold for it, but mine doesn't have this valve, (you can see the blank in this pic) from what I can see mine uses one of these;
Will it be ok to put it inline with that? If so which side of the valve/sensor shouold I put it?
This is a pic of the end of the fuel rail;
Did they use a lower pressure fuel pump on cars which did not have a return pipe for the fuel?
I ask these questions as my ZX still has this cough which I did put down to the fact the lambor wasn't connected, now it is things have not improved. My next thought wass that if they used a lower pressure fuel pump on non-return rails this could be whats causing my problems as the car is dumping too much fuel?
Cheers
Ro
