I have just purchased a Xantia........ Crazy or what!!!!!!!!
It's a French registered 1994 LHD, was told by the guy selling it "it was 1997" (so feel a bit P****D OFF) did not understand the French log book, maybe he did not understand it either, he was English and had been living in France, Told me it did not have a alarm only central locking using key in lock, by looking through the forum it sounded like the plip was not working, checked batteries NIL VOLTS, fitted new batt's still not working, checked with digital camera plip not working, took it apart and found loose joints on LED, soldered joints, retested on camera, OK!!!!!
Tried on car............. Yippeee................car now alarmed.
So if your plip is not working, check the joints on the LED, even if the joints LOOK ok re-solder them, be careful though as they are very close to one another don't short them out !!!!!
Next ... Not a lot of air-flow through vents guessed it may have been the pollen filter but did not know where it was but thanks to this forum found out where it was. took it out .... I think Churchill was Prime Minister the last time it saw day-light, gave it a wash refitted all OK now, will get a new one asap.
I don't know but I'm sure someone can answer my question......
Which Xantia have I got?
The car has Xantia and 1.9 TD on it and that's it, NO other letters or numbers, it's a hatchback has A/C, front windows are electric and it's BLUE
Is there somewhere on the car, hidden away that has its identity?
And can I get a Hand Book, once I know which model it is?
Thanks to ALL for the info I've found up to now, I know a fair bit re A/C (NOT a Citroen specialist) so please just ask and I will try and help.
Bonne Chance
