XANTIA Clarion code++++++++++++
blu
Unread post by blu »
Hi
lost card for stereo Clarion PU1562A
SERIAL N: CLO321x0037092.
Please can you help?
Tried n:2266, 2656, 3261.
thanks :idea:
BLU
Evodad
Unread post by Evodad »
Try this site:-
http://radiocode.proboards6.com/index.c ... =codereqst
It sorted me out a couple of years ago.
foxbat
Unread post by foxbat »
Call your local Citroen Agent quoting Chassis number /VIN number they will be able to get the code for you if it's the same radio that was originally fitted.
citroenxm
Fallen Hero
x 70
Clarion Radio
Unread post by citroenxm »
Hi
Clarion Radios Can NOT be decoded from the Serieal Code!
The chip needs to be read by computer
BUT If anyone else knows that they can please let me know.
I know the older Xantia PRE 1998 Facelift, with Blaupunkt radios can be decoded from the serial.
Regards
citroenxm
A very sad...
1994 XM 2.1 d auto
meexi
Unread post by meexi »
clarions can be decoded as i have a decode program you need the last 4 digits of the barcode and if there is two barcodes then you use the second one
2004 C3 XTR HDI 16V 92bhp
2004 Xsara Picasso Exclusive HDI 16V 110bhp
1989 Peugeot J5 Hymer B694 2.5td intercooled 8v 96bhp
blu
Hi, I found some more numbers, on the top left ( 286-8476 could be the bar code):?:
on the top right 96-27939980.
Thank you for your help.
BLU
tanto
Unread post by tanto »
i put the last four digits of the first one into the clarion code calculator it gave the code 3644
the last four digits of the second one gave the code 4554
1996 xantia sx 2.0L 16v
if at first you don`t succeed get a bigger hammer
meexi
same as what i got
