With or without the vacuum pipe connected, my car idles much better with the ignition at maximum advance. ie with the dizzy turned entirely one way.
Is it safe to run it like this, or should I set it to 8degrees BTDC and suffer a lumpy idle and judders at low speeds?
It has to be said that the car is fitted with a 280 degree duration camshaft.
Any help gratefully received.
205 xs ignition timing
rossd
