Ignition barrel change
Has any one out there ever changed the ignition barrel on a xantia?, & kept the same key!!
Mine is starting to wear out from the inside, as when I remove the key, it doesn’t always turn off all items as I found out last night when I tried to deadlock it with the key.
dom
ingnition barrel change
JohnW
Dom,
No I haven't - a good locksmith may be able to advise.
But I'm curious to know if your key ever comes out hot after a drive? Mine is intermittently cold, warm and uncomfortably warm even though the switch behind the lock has been replaced.
I've found getting a Xantia key made at all quite a challenge in Western Australia. So I doubt I'd be able to get a lock modified.
Cheers
John
[/quote]
Cheers
John
[/quote]
shaunthesheep
john, have you got any more ideas on how easy it is to replace the barrel & keep the same key??
will keep you informed on your 'hot key' problem, how long a drive are we talking about?
you can get spare keys from (dare i say it) main dealer, as the locksmiths i've spoken to say it needs a four sided blank key which are quite hard to come by.
dom
dom
fmuunster
Hi Ihave recently had a barrell modified to accept the original pattern key and replacement key made. The company concerned was SS locks in Darlington they made the replacement key modifided the barrell from a scrap car all done mail order for around 22 pounds there advert is in the auto trader. Frank.
f.mooney
f.mooney
shaunthesheep
philcut
I'm not sure if this the info you want,but try this link-
http://www.tramontana.co.hu/citroen/body/body.html
If i can't get this to hyperlink-type in the bit upto .co.hu/citroen,click on bodywork,and scroll down the page.<img src=icon_smile.gif border=0 align=middle>
fmuunster
