seized height corrector ?
talisker
after working on my 96td xantia today i had the suspension on high but when i dropped it down it wouldn't come back up, so i got some lube on the height corrector linkage (the plastic ball joint appears to be ok) and worked it with the pliers but now its stuck on its highest setting, if i pull the lever back with the pliers i can get the back end to drop down but as soon as i let go it rises to its max setting again, also i need to use the car tomorrow am i likely to damage it driving it like this or will i just lose a few of my fillings
- x 1240
If you have given it a good soaking with WD40 or oil, it will quite likely free of when you drive it, unless you have bent something. Try driving it round the block before you leave. You can drive it with the suspension up at the back, although it wont be very comfortable! The front is a different matter as the drive shaft boots wouldn't last long, but I take it thats OK.
talisker
ive tried taking off the rod that comes from the height adjuster inside the car, and i can move the lever with some pliers and adjust the suspension up and down but if i let the height corrector lever sit with out any pressure on it the car rises to the max, i've given it another spray of wd40 and will have another look at it in the morning, it's my own fault i was bragging at work the other day about how my car never goes wrong
- x 1240
Sounds as though something has upset the original setting, could still just be sticking or could be that something is bent. The only sure way to correct it is to adjust the height by slackening the clamp around the anti roll bar and rotating it one way or the other with the height setting rod disconnected. Dont do this without plenty of clearance under the car or you will have it down on top of you!
talisker
jeremy
Citroen suspension isn't generally unpredictable but the cars are heavy. The problem is that if you give it an instruction - like adjusting the height corrector - then it will drop - if that's what you've adjusted it to do. there is in fact a built in delay in the operation of the height correctors - which probably makes it worse.
If you open a pipe for example between the height corrector and the rear suspension cylinder (which can mean a brake pipe as well) the back suspension will collapse rapidly.
Recently a memmber of an Australian Citroen board was killed when his car fell on him.
Treat it with caution and you'll be Ok. I always try and have a back up support in case the worst does happen - like a wheel ramp under the sill or something - I'd rather be alive and cursing a bent sill . . .
jeremy
BonceChops
Mandrake
- x 694
While I'm all for safety warnings about working under hydraulic Citroen's, (it *IS* dangerous without supports) there has been no confirmation in this particular incident that the person involved was working under the car relying only on the suspension.BonceChops wrote:Very good advice Jeremy. Lets hope his tragic death teaches us all a good lesson.jeremy wrote:I'd rather be alive and cursing a bent sill . . .
Please work safely my friends.
In fact from the following post by "dogboy" on Aussiefrogs it appears he may have indeed had support stands under the car which gave way or fell over: (something that could happen with any car...)
http://www.aussiefrogs.com/forum/showth ... 806&page=3
Without hard facts lets try not to speculate too much as to exactly what happened...
Regards,
Simon
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
talisker
ok here's an update the linkage and all rods are free, so i suspect that the corrector is at fault, i'm not sure how easy it should be to move the height corrector i can move it with pliers although it does take a bit of an effort and can get the car to go up or down but if i let the corrector sit were it wants to with no pressure on the lever it rises to it's max setting, iv'e given the lever that connects to corrector a good tug and now the car is sitting on the floor and refuses to come back up, i've heard about people servicing correctors but do you know if it's possible in situ as some of the pipes don't look like they are going to come undone, ive also managed to bend the pin on the lever that conects it to the corrector
- x 94
its unlikly that its your H/C at fault as they very seldom give trouble,i would sudgest you have bent something,also your unlikly to move the adjustment without loosening the pinch clamp first,but if you are going to dismantle it its best to remove it and 99% of the time they just need a good clean in petrol whilst it is in bits,they are very simple in side
regardas malcolm
regardas malcolm
talisker
