XM Drivers lock
Jade Falcon
XM Drivers lock
Unread post by Jade Falcon »
Okay, I first posted this on Andyspares.
My drivers door lock just 'spins' in the lock, nothing will make it work. I've removed the grommet and tried tightening the hex screw in case it was loose.
Now I've heard that its a common problem for the locks to wear out, necessitating a replacement of the barrel.
What would any of you say is a reasonable cost.
Here is what I was quoted at Flemings of Ayr.
Inner and outer Cylinder-£77.50
Labour to shape the blanks for my key and fit the lock-£90
This, IMHO seems a bit excessive for labour.
1994-95 Citroen XM 2.0 CT Turbo Exclusive Hatchback
jeremy
Unread post by jeremy »
GSF list a door lock set for XM's - 92> for £45. There's something else for the estate as well.
jeremy
jeremy
Mandrake
x 694
Unread post by Mandrake »
If you're willing to give it a go, they can usually be fixed. They don't "wear out" as such, but a sliding section in the lock can seize up and need lubricating and freeing up. See the following:
http://homepages.igrin.co.nz/simon/imag ... _locks.pdf
I used this info to succesfully fix the drivers doorlock on a Xantia which was also spinning around...
Regards,
Simon
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
Jade Falcon
Many thanks to both of you, I'll give the lubricating a try. Personally I think the labour charge that Flemings was wanting was way over the top.
x 1240
Unread post by Peter.N. »
If you push the key hard inwards as you are turning, it will sometimes grip. Mine was worn, so I swapped it with the passenger door, but you do have to do some dismantling as they are 'handed'. I have now got a replacement remote reciever so dont use it anymore!
Jade Falcon
Peter.N. wrote:If you push the key hard inwards as you are turning, it will sometimes grip. Mine was worn, so I swapped it with the passenger door, but you do have to do some dismantling as they are 'handed'. I have now got a replacement remote reciever so dont use it anymore!
Oh I've tried that, and eventually that stopped working. The lock meets absolutely no resistance when turning.
x 1240
Oh well! as you were then!
Jade Falcon
Peter.N. wrote:Oh well! as you were then!
Thanks for the thought though, as too often its the simplest things that are the solutions. :)
Jade Falcon
Mandrake wrote:Hi,
Regards,
Simon
Many thanks Mandrake, I tried this today and it worked. I don't really know what I did, but its possible one of the tiny ball bearings wasn't in its right place. Whatever, prior to dismantling, the plastic clip at the end of the mechanism wasn't turning, after reassembly it was.
Thanks a lot, this has saved wasting a large amount of money on dealers rates. :D
Mandrake
x 694
Jade Falcon wrote:Many thanks Mandrake, I tried this today and it worked. I don't really know what I did, but its possible one of the tiny ball bearings wasn't in its right place. Whatever, prior to dismantling, the plastic clip at the end of the mechanism wasn't turning, after reassembly it was.
Glad to hear it... :)
Did you split the barrel apart into two pieces and grease it as suggested in the article ? Otherwise it might not last, as it is the sliding section that sticks preventing the balls from dropping into the right place...
The one we fixed is still going strong after 6 months.
Regards,
Simon
Simon
1978 CX 2400
Jade Falcon
Regards,
Simon
I greased it a bit, but to be honest, the barrel was well greased already, that definitely wasn't a problem. I did get rid of some of the gunk that had collected though.
