This one is a little odd though. I am missing the 12V supply to the fan unit - as a temp fix I have connected a cable to the 12V fan supply so this is ok, it leaves fuse 20 but never gets to the fan. Anyone know of any connectors for this anywhere please? The original cable goes up towards the top of the dash then disappears from sight. When I start the car the fan will run slowly ( with setting on max ) for a couple of seconds then stop. After a while it will do the same thing again and again. I know the fan and speed controller works because I replaced the transistors with a couple of MJE2955's. I have a 1Kohm pot supplying base current to the speed controller and can vary the speed of the fan ok. I have tried another ECU unit and another heater control unit with the same thing happening.
I hope someone can help me as it is a little cold at the moment.
