from what many of you have said the squealling noise i "sometimes" get when starting off in low gear may be related to the tension or wearing of the above. Can i confirm as i cannot find a mention of one in the Haynes, that this is what is known i many other cars as the fan belt? Or am i way off?
Also any idea how much it costs to buy an new one.
My local citroen dealer quoted me 20quid inc fitting - have they got it wrong, seems cheap or is it very easy to fit?
?auxillery drive cable?
_________________________
Xantia TDS, LX (1995)
- My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars. - x 1205
If its only the screeching noise you mentioned, thats because belt isn't sufficiently tight to stop it slipping when the alternator load is high i.e. when you have just started the engine and the voltage has dropped. The output of the alternator can go up to 50 or 60 amps which can take up to a horsepower, but only until it has pulled the battery voltage back up so that it has recovered from the heavy load of the starter. so, the noise is just the belt skidding, tighten the belt and it should stop. Unless the belt is obviously damaged or badly worn, it should be OK. Belts are much stronger than they used to be!
