xantia key pad
john gooding
xantia key pad
Unread post by john gooding »
both lights come on together on the key pad, after very slight accident damage to the o/s front, cant enter the code!! it,s not the problem goughy had, ie, fuses. been off the road 18mths. its an 1.8 16v, desperate!!!!
mg46783
Unread post by mg46783 »
HI, this is noty definitive by any means but on the o/s is quite a chunk of the loom and the ECU.....it would be worth checking to see if any wires have been damaged and thereby affecting the circuit. Other than that youre into fault codes and painstaking tracing - unless of course , anyone else knows better.
Cheers
Mike
Salmond
Unread post by Salmond »
Had same problem on my 2.0i SX.
Was intermitent though and would cure itself if left for 5 mins.
Had the two lights and would bleep 3 times when I turned the ignition off.
Cured by disabling. Not ideal but was making me late for work.
Can't help you but would be intersted if anyone had a solution.
Darren
D.Slatford
Unread post by D.Slatford »
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote>
<hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>
I have the same car, '95 M reg, and exactly the same problem. I once found it was worse in damp weather, but now hardly ever works so resorted to the same solution, turning the bloody thing off.
Darren, did you find that both LEDs come on whether or not you enter the correct code? It takes any four digits on mine to make that happen. Eventually it will work, either due to the time passed, or because I end up entering the code really, really quickly. I don't which is making any difference. Would love to know whats causing it.
I also have an alarm that doesn't sound and a red alarm led (by the clock) continually lit. Have replaced the alarm ecu already, no effect. Main and independant citroen garages can't offer any help. Beginning to wonder now if my cars victim to that reputed shoddy citroen wiring...
dan
Salmond
Dave,
Sorry for not responding earlier haven't checked this thread for sometime.
Exactly the same mate!
Had the car just over a month now and come to think of it think it might be related to the damp!
Was fine for a while (while the weather was fine anyway)
I need to change the code anyway perhaps that might make a diference!
Regards
Darren<img src=icon_smile_cool.gif border=0 align=middle>
