Hi All,
Just a very quick and simple question - hope someone could kindly answer this please. I would like to check the condition of the timing belt on my 406 coupe fitted with a 2 litre 16 valve engine - series 1 1998 year. The upper timing belt cover is plastic and held on by one clip at the top and two 10mm nuts. I have removed the clip and two nuts but yet the cover will not move. I have checked along the sides and back of the cover but cannot fell any other retaining bolts/nuts. Haynes does not help. I am sure some of you guys can help me - do I need some brute force with a screw driver? Cheers
Removal of plastic timing belt cover
Horse
kg7657
