Mulitgrade oil gets thicker when its hot right? and thin for easy starting when its cold? Right?
So why does it say to warm the engine up before draining the oil
Or did I get that all wrong about multigrade oil?
Not entirely - just reverse your theory and you are back on trackrpaco wrote:Or did I get that all wrong about multigrade oil?
Hmm,AndersDK wrote:At times you want a thicker oil. That could be in hot climates where you never get temps below 5-10degC. Then you'd use a 15W-40 or 20W-50, even a 25W-60.
A mistake ?Mandrake wrote:Hmm,AndersDK wrote:At times you want a thicker oil. That could be in hot climates where you never get temps below 5-10degC. Then you'd use a 15W-40 or 20W-50, even a 25W-60.
I've just noticed that I've put 20W-50 in my petrol Xantia at the last oil change, (Castrol GTX 20W-50) and I wonder if I've made a mistake ?
Mind you here in the northern most parts of New Zealand where I live we probably have a somewhat hotter climate than the UK. In summer (just passing now) we have had days exceeding 40 degrees, and in the middle of winter we usually get down to about 10 degrees, and on very rare occasions maybe 6 degrees now and then, but never below 0. Typical temperatures in autum and spring are around 20-30 degrees.
According to the owners manual 20W-50 is suitable for -10 to +50c while 10W-40 is suitable for -20 to +40c.
Have I made a mistake in my choice of oil or am I within the working parameters of 20W-50 ? Would 10W-40 have also been ok here or would exceeding 40 degrees in the peak of summer be outside the operating range for 10W-40 ?
Regards,
Simon
