cheers
roy
You reach the filter from underneath. Remove the carpet / felt from 'above the passenger's feet', below the dashboard, and you'll se the bottom of the housing, which either slides off or has a few screws, depending on model.I found the housing ok and because I had the time I quickly removed the fan assembly and could see the filter... but no way could I find a way to get to it.
