My recent purchase, a 1994 1.9d lx Xantia, is a little smokey and lumpy on start up. I've searched the old threads, but Im still not sure. I've replaced the glow plugs (checked them before putting in), leak off pipes, serviced it, put some injector cleaner in it, etc. The car starts on the button, after the glow plug light goes out. But its very lumpy, and there is a load of smoke that engulfs the car (embarrasing). After about 20 secs, the car runs fine, and there doesnt seem to be any smoke. It only happens if the car is cold, or left over night. It does seem only to be lumpy when the car is rising, and leveling after being left over night (no idea if this has anything to do with it - doubt it though, since reving the car doesnt make it less lumpy). But again, if you wait around 20 secs the car is then smooth. Also I can probably rule out injectors since the car runs fine otherwise?!
Any suggestions would be helpful.
