I have a dead electronic speedo on my Xantia TD.
Can anyone suggest a test procedure ?
So far the only thing I know for certain is that the connector to the sensor at the diff. is clean - no oxidation - but chasing the wiring is awkward.
Can anyone point me to a link to a decent wiring diagram as the ones in the Haynes don't seem to cover this.
Dave.
Xantia Speedo
DaveW
Xantia Speedo
Xantia Forte 1.8i, 16v X reg.(09/2000) 93K, aircon
davehughes
I haven't experienced this with Citroens yet, but I used to be a BMW mechanic and the diff sensors used to be prone to failing on all models across the range. Try one from a scrapyard as a cheap process of elimination to start with before messing with the wiring. If it isn't that it might well be the instrument display, but it's easier to change a diff sensor than bugger around with the instrument display
1993 Citroen Xantia 1.9 SX TD 120,000 Metallic Grey
DaveW
Thanks for the reply.
I was hoping that someone would not say that!
The nearest scrappie likely to have a car or two is quite a jaunt away (I live in the sticks, N. Wales)
Is the sensor 'potted' in it's housing or just clipped in ? and is it just a Hall effect device?
I have a couple of 12v. Hall effect devices from other equipment so may be able to effect a repair if I can just locate the next connector and check to see if the sensor is outputting pulses.
I have read elsewhere that a problem can occur with the "speedo interface box" that allegedly lives behind the glove box ?????
Anyone heard of this beastie ?
There must be a full wiring diagram somewhere -
Dave.
Dave.
AndersDK
dnsey
- x 19
