Recently when pressed the clutch pedal in i heard the sound of something plastic go, since then the clutch operates fine, but when i press the clutch in approx two-third down a hear a ‘click' noise from the clutch.
Even more bizarre with i lift the clutch up when at rest (e.g. with the top of my foot) and then press the clutch the click noise disappears for around 10 presses, until the noise returns
i have tried lubricating the white plastic thing and surrouding area with fluid but no change
I believe the clutch was changed @80k miles by the previous owner (now done 95k with gentle use), i have no reason to disbelieve this but i don’t have the documentation, ive had no problems prior to this. Can anyone point me in the correct direction?
Many thanks
clutch problem
clutch problem
currently no citroens
1.4 2000 forte now gone too
xantia 1.8i 16v dimension 1996P now gone,
i had a look down there, it dont look broken but i could be wrong, surely if its gone then that would be it.Evodad wrote:Wonder if "The Clip" has broken (see many other posts) & the cable is being held onto the clutch pedal with a wing & a prayer.
Changing "The Clip" is doable without removing the dash or clutch pedal (I've done it), but it requires much much patience & dexterity.
also why does the noise go (for a bit) when i lift the clutch up, strange
you would not be able to see if the clip was partly brocken without removing it,as the bit that breaks is in side the nylon block,you might find just one side of the jaw has snaped off,the clip has two blades which sit under a bullet shaped cable end,so if one side of the clip has snaped off or bent it wont be long before it goes completly
regards malcolm
regards malcolm
so if one side was broken off, would that account for the 'click' when the clutch is pressed 2/3 down?citronut wrote:you would not be able to see if the clip was partly brocken without removing it,as the bit that breaks is in side the nylon block,you might find just one side of the jaw has snaped off,the clip has two blades which sit under a bullet shaped cable end,so if one side of the clip has snaped off or bent it wont be long before it goes completly
regards malcolm
- therealyeti
Does the clutch cable have the adjusting nuts on the end in the gearbox lever, if not it might be a cable with an automatic adjuster, just like mine, having much the same problems, have new cable but just not got round to fitting it yet,usual syndrome, as long as it drives it doesnt get done. also, i think the manualadjust cable would be adirect replacement, but didnt think of that till i`d ordered the dearer auto adjuster,
