Out of the blue today, the battery charge light on my 2001 306 HDI came on.
I have just checked the voltage across the battery, and got the following readings
Engine off 12.9v
at idle 14.9v
at approx 2000 revs 15.2v
at idle with lights, heater and stereo on 14.8v
From the readings, it would appear to me that the alternator is doing its job, but the battery light stays on with the engine running.
One other new thing that is happening (just noticed while getting the voltage readings) is that when I turn the key to the accessory position, all the warning lights come on APART from the battery light. When I start the engine, all the other warning lights go out (as they should) but the battery light comes on.
This car has never given me any problems in 4 years, but am confused now as to what the problem is....any ideas??
Alternator help needed
rotodiesel
There is no problem with the alternator - the trouble is with the switched feed on the "battery" side of the warning lamp. This feed causes the lamp to light when the key is turned before the engine starts. When the engine is running, there is about 14V from the alternator of the non-battery side of the lamp, and the same voltage from the (charging) battery on the other side, hence the lamp goes out.
Check fuses first of all, then ignition switch. There might be an ignition controlled relay on your car - check this too. I use the word "ignition" in the general sense - its a diesel!
rotodiesel.
rotodiesel.
xdavex70
fastandfurryous
- x 4
pugxpert
has the electric windows stopped working as well? fuse 22or 28 blows not sure which one and this puts battery light on and loss of electric windows.cause water ingress through rear wiper spindle into rear wiper timer in tailgate.only effects 5door /3door not estate.
EP6T petrol turbo nice engine in the 207 GT and the new mini....
PowerLee
xdavex70
pugxpert - you were spot on....the fuse was blown....I put another in and that blew straight away. What you have said make sense as the other day my rear window was really misty which I thought was odd, and the rear wiper made an odd noise.....
So to fix I guess I should seal any gap around the rear wiper, let everything dry out and replace the fuse?
xdavex70
Follow up
OK - last night I tested the electric windows as per Pugexperts comments and found they were not working. This morning I checked out the spindle round the rear window wiper and found it was leaking.
So I have just dried the area off and sealed it up. I also took the blue (is it a regulator?) off, only to find it very damp, and the terminals corroded. So I let it dry out, cleaned the terminals and put it back.
Then I replaced the blown fuses, and am glad to report everything is back in order again, with the battery charge warning light coming on witht he key in the accessory position, and going out once the engine is running.
Thank you to those that took time to respond, and special thanks to Pugxpert, as I would have never have thought to check the rear wiper for a leak as a possible cause of the problem
pugxpert
fastandfurryous
- x 4
rotodiesel
I wasn't too concerned about the low load charging voltage because many (cheap?) digital multimeters are prone to giving wrong readings when there is a high ripple content in the voltage being measured. As the alternator is loaded, the peaks of the ripple decrease and the apparent DC value falls.
Valeo regulators are set too high anyway, giving short lamp life and battery gassing on most French cars. I just live with it and change the lamps, but this can be a pain on vehicles with inaccessible panel lamps.
rotodiesel.
rotodiesel.
