Hi Guys
Can you help me on this, my Xantia heater smells of burning rubber or coolant, it was that bad I thought the exaust was blocked
Xantia Heater smells of burning rubber?
- x 1240
If its coolant leaking from the matrix, it would normally have the effect of steaming up the windscreen, if this isnt happening, and If its definitly coming from the heater, it could be an electrical problem, although this is unusual. Does it have a pollen filter? if so, could be some biological activity going on in there. Can you give us a more accurate description of the smell?
Gabriel
It gives me a headache its as if the fumes are carbon monoxide, hence my feeling that my exhaust was blocked, I have read another section and someone gave mention to a leak in the cooling system. I have looked for some sign like a green leak, I have even lifted the bonnet to see if any smoke is there, but no each time the heater goes on I have to open the window. If the heater has gone would it smell and also I notice that the heat is very hot even at 18c.
dnsey
- x 19
- x 1240
I would agree, you could have an exhaust leak in the engine compartment and the heater fan is drawing it in. Is it a diesel? if so, open the bonnet before you start it up from cold, then start it and look for blue smoke around the back of the engine. If its petrol its more difficult as you cant see the exhaust unless you can introduce some redex or similar into the air intake.
Kowalski
The air intake for the heater is at the bottom of the windscreen, in front of the bonnet. Your bonnet has a seal at the rear edge so fumes (or exhaust) from under the bonnet can't easilly get taken into the heater intake, so I'm doubtful whether its under bonnet fumes that you're smelling. If you have the fan on cold, the air comes from the same place so if you get the smell then too its more likely to be from the outside. It sounds like a leaking heater matrix, a curry / burning rubber smell is normal when you've got a leaking matrix.
jeremy
I agree - make sure you've not got fumes entering the car as this could kill you.
Sometimes - particularily when the car or heater hasn't been used for a time there can be an accumulation of dust and dirt which smells horrible - I had this on our ZX 1.9D last autumn - and its cleared now. I thought it was early signs of matrix problems - but as the thing never looses a drop of water it wasn't.
There have been cases of evil-smelling fungus affecting these things - some time ago on here there were a number of posts - and a search (fungus?) may help. I also seem to remember someone's problem was curry powder!
jeremy
8304
- x 1240
Gabriel
- x 1240
Gabriel
Clogzz
- x 40
Gabriel
OK, I will not put the hose into that area, so, do I have to take off the window wipers first to get to this area? Also this burning rubber smell is to do with the heater, I used the fan on cold and no smell, as soon as the heater is on the smell starts, is this the air intake? or a problem with the heater?
Mandrake
- x 694
I also have a slight smell when I turn my heater on which isn't there on cold... I'm not sure that I'd describe it as burning rubber though....its not really a smell that I can describe at all....
Could it still be the pollen filter even though it doesn't smell on cold ? What else could it be ?
Regards,
Simon
Regards,
Simon
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
