Leaking Suspension Strut Top
Gregg1100
x 5
Unread post by Gregg1100 »
Hi All,
Just noticed LHM oil coming from suspesion strut top;- see pic link;
http://img.photobucket.com/albums/v676/ ... rutTop.jpg
Is there a seal between the top of strut top and the black rounded bit underneath ?, and if there is, can it be obtained seperately. Bloody Cits, just when you think all is quiet, they rear up and bite your bum. :(
Regards,
Greg
90 Kawa EN 500 A1- was running---now dead again
04 Kawa GPZ 500 E10 -alive and well.
54 Fiat Punto 1.2 Dynamic
Old Xantias- 16v 2litre 1997 VSX, 2 x 1993 TD Lx, S2 SX 1.9TD
Old Bx's--3 x 1.9 D, 1x 1.6 Auto, 1 x 1.9 GTi, 1 x 1.9 TZS
AndersDK
Unread post by AndersDK »
Sure its not simply the sphere seal ?
You have a PM on how to trace down the strut top seal.
Anders (DK) - '90 BX16Image
Mandrake
x 694
Unread post by Mandrake »
A better picture would help a lot... that one is too out of focus and in too close to be able to make out much from it...maybe a couple of pictures from different angles and a bit further back...
AFAIK the only possible leak points for a strut top would be the sphere mounting face, the pipe union, or the nut at the top. (The latter being very unlikely - just prise the plastic cap off the top to check that possibility)
Regards,
Simon
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
Gregg1100
x 5
Hi Anders and Simon,
Piccy was a bit iffy I know, it was just getting dark when I took it. It seems that there are 2 seals in there somewhere, according to Cit main dealer , and being proved by Anders. I have ordered those, about a week they said, so will have to keep putting in the LHM. I will get this done and MOT`ed then bung it in for a TD, but a basic one, I think.
Thanks,
Greg
Gregg1100
x 5
Hi Anders,
The leaky suspension top was only a slightly loose union nut holding the supply pipe to suspension top. Nipped it up and goodbye leak.
I have some suspension leg seals now--useless, nearly £10-
Greg
AndersDK
Nearly £10 wasted on parts following an advice not fitting the bill :shock:
- plus all your labour and swearing :roll:
- how can I ever pay you back :cry:
x 94
Unread post by citronut »
sealy you HE HE HE
regards malcolm
