C 5 5th gear
Gavin123
C 5 5th gear
Unread post by Gavin123 »
Anybody know why the car is still in 5th gear even though you take it
out of gear. I have to put the gear stick back into 5th and bring it
out again before it is out of gear
406 V6
Unread post by 406 V6 »
This seems clearly a cable problem.
I personaly advise you to handle this to a dealer. I've been there, saw it then forgot; even on an elevator, the cables at the gearbox siede are a bit inaccessible, and you have to remove practically all the heat-shielding under the belly pan to access the cables at the selector lever.
Francisco
C5 2.0HDI smoothly riding on 1.8l version spheres :D
When the hearts beats like a pressure regulator you know it means one thing: Love
Citroën - pacemaking since 1955
Gavin123
5th gear
I did take it to the dealers and they changed the cable, made no difference, they then put on modified cables which made it better but still has the same symptoms
Gavin
