xara 2001 hdi
1939
xara 2001 hdi
Unread post by 1939 »
hello i wonder if any one knows the part number for the timeing belt on a 2001 xara hdi 90 engine is as a siemens fuel pump fitted not sure if it as 141 teeth fitted or not hope some one can help thanks
AndersDK
Unread post by AndersDK »
If the engine code for your Xsara HDI 90 is DW8B
- then the timing belt part no is : 0816 93
Timing belts for other HDI's or diesels have different part no's.
Anders (DK) - '90 BX16Image
1939
Re: xara 2001 hdi
1939 wrote:hello i wonder if any one knows the part number for the timeing belt on a 2001 xara hdi 90 engine is as a siemens fuel pump fitted not sure if it as 141 teeth fitted or not hope some one can help thanks
sorry i should have put the engine number in ( dyjm3016110also would any one no were i can get the crank shaft pullie other than the main citroen dealers thanks
