Xantia Crankshaft Bolt
walcit
Unread post by walcit »
1.9d lx Xantia. Which way do you turn the crankshaft pully bolt to take it off (as you look at it). I just cant get it off!!!! :evil:
Kowalski
Re: Xantia Crankshaft Bolt
Unread post by Kowalski »
walcit wrote:1.9d lx Xantia. Which way do you turn the crankshaft pully bolt to take it off (as you look at it). I just cant get it off!!!! :evil:
Its a standard right hand thread, so you need to turn it anti-clockwise. The bolt has thread lock on it so if you get the engine hot (or at least warm) beforehand that will help to soften it.
I didn't have any trouble with the ones I've done, I used an 1/2" drive 18" breaker bar but I had the engine locked solid with the pin in behind the starter as well as 5th gear and the handbrake on. If you don't lock it up solid you won't be able to shock it which might be what you need to do to get it to move.
There are stories on here about people having real trouble shifting that bolt and people have had to resort to using the starter motor to help them shift it (I wouldn't recomment that). Use the search function above if you want to find out more...
rory_perrett
Unread post by rory_perrett »
Definately need the engine hot. Last time I did this the engine was hot but in the time it took me to remove the plastic under tray it had cooled sufficiently to make removal of the bolt impossible. Ran the engine up to temp again and out it came.
x 1240
Unread post by Peter.N. »
I have on more than one occasion had to use a four foot tube as an extension to get sufficient leverage. On one XM the ammount of force needed caused the clutch to slip! So,I had to remove the bottom flywheel cover and jam a large screwdriver between the edge of the housing and the into starter gear ring, then pull, that did it! If you have a flywheel locking pin of the right diameter, and you can get it in! that's the best route.
Gregg1100
x 5
xantia Crankshaft Bolt
Unread post by Gregg1100 »
To get crankshaft pulley bolt undone easily, fit a good socket or ringspanner on head of bolt, turn crank so that spanner/socket is jammed against body ( anticlockwise ), then just give starter a flick. Instant bolt undo. It`s how the trade do it, and will do no harm.
Regards,
Greg
90 Kawa EN 500 A1- was running---now dead again
04 Kawa GPZ 500 E10 -alive and well.
54 Fiat Punto 1.2 Dynamic
Old Xantias- 16v 2litre 1997 VSX, 2 x 1993 TD Lx, S2 SX 1.9TD
Old Bx's--3 x 1.9 D, 1x 1.6 Auto, 1 x 1.9 GTi, 1 x 1.9 TZS
x 1240
Sounds fair enough, I will try it next time.
walcit
Managed to get it off. Got it off by using a very long bar from above. It took some go though!! Just glad that its out. I ould see after taking it off there was a lot of locktite on it :D
x 1240
Well done! You need to put it back on tight to, although I havn't had a problem, I have heard horror stories of them coming loose and chewing the crankshaft up!
DaveW
Unread post by DaveW »
I have done this a few times (on BX's) using a 1/2" socket with a long extension bar resting on an axle stand close to the bolt.
Adjust the axle stand so that the extension is parallel to the ground, fix a breaker bar into the extension and then a 5ft + scaffold tube and lean on it.
Never failed ...............so far.
Not as exiting as using the starter motor but very controlled.
Dave.
