C5 Headlight Bulb change
stuartmunn
Unread post by stuartmunn »
Hellllpppp!
Trying to change the dipped headlight son my C5 estate (2002)...
Is there a "technique to doing this as it appears impossible ....
How do you remove those plastic covers... is there a special tool. or do you just break them
I can't believe I have to go to a delaer to change bulbs...
Cheers
Stuart Munn
Stonehaven
Scotland
mezuk04
Unread post by mezuk04 »
Im not sure but im sure ive read that the bumper has to come off or something similar :?
Volkswagen Golf 59' 1.6TD S :(
stuartmunn
Wind up
Mexuk04
Surely you are winding me up!!
Though with Citroens ... I can almost believe it ...
Nice car though and so far no problems...
Cheers
Stuart
ralph
Unread post by ralph »
The studs that hold the plastic covers over the battery etc are in two parts. Prize up the centre part (which you'll see is a pin), then the rest will come out more easily.
Once you've got to the back of the headlamps, unscrew the big plastic cover and marvel at how bad access is.
The bulbs are held by a metal spring clip, then they come out with a slight turn. The bulb fittings are conventional, but take your time.
I did a mate's bulbs last week and it took half and hour of fiddling - since you can't see what your hand is doing.
Enjoy! :twisted:
2000 Clio 1.2 8-valve
Couple of Merc 190s
2009 petrol Focus
1998 Xsara TD, 293K - gone but not forgotten.
205s, 405, ZXs all loved and crushed.
mezuk04
Zx's arent too Bad
Xantia's well i took one look and moved on to the washer jets
C5's never it would seem :lol:
So you dont need to remove the bumper, did I scare you hehehehe :P
stuartmunn
C5 bulbs
Yes I was scared...
Thanks for the advice guys, I recall similar access issues with my old Mini ... you needed arms the size of a 9 years olds but with the strength of a wrestler to work on it....
Seems my plastic clips are in one piece but then its possible my eyesite is failing me!
I'll have another go at the weekend, one the scars heal up!
My Jag S type is much easier in the headlight area...5 minute job.
Cheers
406 V6
Unread post by 406 V6 »
Remove the battery first if it's in the way. It will prevent a lot of cursing (i know, i had to change that lamp the other week :evil: )
Francisco
C5 2.0HDI smoothly riding on 1.8l version spheres :D
When the hearts beats like a pressure regulator you know it means one thing: Love
Citroën - pacemaking since 1955
x 1240
Unread post by Peter.N. »
...And then buy a new radio, because you've forgotton the code!
x 1056
Unread post by wheeler »
Peter.N. wrote:...And then buy a new radio, because you've forgotton the code!
C5 radios dont have codes as they are programed to the cars chassis number.
mezuk04
Theres always one :x
Mr. Smarty Pants :P
hhehehhehehe
johnway
C5 Headlamps
Unread post by johnway »
Hello,
Yes they are a pain, but perseverence wins the day!! Remove the battery first, then remove the large black plastic cover, exposing the bulbs and retaining clips. I found that the wife's vanity mirror was ideal for watching my fingers perform the unclipping/removal and replacement of the bulbs. The offside is a little b....r !! Much jamming and skin scraping required but with the mirror as an aid I eventualy got the job done. Be careful to get the bullbs seated correctly before re-clipping. Have fun!!
Regards,
John.
My chariots : 2002 Pug 406 110 HDI Executive Estate 138K
1995 Citroen AX 1.0 Debut 26K
I Blame it all on my Dad!! (Sadly had to give up driving & his 2nd BX) but Mum still has a C1.
406 V6
Guess where most of the cursing came from... i got the new H7 stuck the wrong way, and with no pliers to help getting it out it was a pig of a job...
Francisco
Sir Clive
Unread post by Sir Clive »
The H7 lamp goes in with the flat at the TOP, not the bottom, as you might think. I too have spent an hour trying to put one in upside down....once :x
I found it possible to do without removing the battery, but it isn't an easy job whichever way round you do it.
Good luck!!!!!
stuartmunn
let there be C5 light!
Gents
Thanks for all your help as my hands are starting to heal up... I'll have a go on Saturday daylight permitting... taking the battery off is a good suggestion.
The mirror is a good idea and I now have my own vanity mirror for doing such jobs, trouble is I can never find it in the garage...so I still end up borrowing my wifes. Which gves me an excuse to poke about in her makeup bag...which is always a pleasure... but you don't want to hear about my perversions do you?
I like the quick battery take off clips, a great idea! anyone know where I can buy them? they'd be ideal for use in my boat.
Cheers
Stuart
Kowalski
Unread post by Kowalski »
Off topic but...
C5s are getting cheap now to the point where I'm tempted to upgrade to one. My major gripe with the Xantia (mostly with it being winter) is that the dipped headlights aren't so good, especailly when the car is covered in salt like it is now.
How do the C5 dipped beams compare to the Xantia dipped beams? Are the HID/Xenon headlights worth upgrading to on the C5?
