I have a 1997 2.0 16V vsx and notice on my tyre change today I need to replace my front discs and brakes. ABS model of course. As a DIY jobbie, could any of you good folk advise me of the time to allow for this one, and any pitfalls to look out for. Thanks.
big bazza
Xantia front discs
JohnD
- x 72
Oystercatcher
MrXantia
I changed brakepads and disks on several Xantias (I'm on my 4th Xantia now) and its getting easyer every time. Allow about 1 - 1½ hour to do the job well, and remember coppergrease on the back of the pads (carefull, not on the front!!).
The retraction of the pistons is actually not such a tideous job. Just turn it 1/4 turn and then apply pressure with some tool. I usually use a little crowbar, but a big screwdriver would also work. By turning 1/4 and pressuring the job is done in 2 minutes without turning yourself silly.
Have a nice one. Lars P.
shaunthesheep
regarding changing the brake pads,
i've also found that if you take the edge off the brake pad corners, i've found that this will help in stopping any squeal afetr you have copper greased them.
i've also fould a brake pad wind back cube made by draper, heres the link:- drapertools.com
keep it citroen
dom
keep it citroen
dom
