Just been out for a local drive (fortunatly) and heard a lous hissing sound.
Investigations have found a leak on a metal suspension pipe by the rear LH wheel. The LHM is flooding out of the carrier tray right next to the rear wheel. I think that I can feel the unions next to the rear strut but how long is the pipe. Does it run from front to back of the car?
Are there any special problems with changing the pipes and is it a DIY job?
Nigel
Xantia estate Major leak from Suspension pipe
nigelc116
Xantia 1.9TD Estate R Reg 1998, Green
reddeathdrinker
nigelc116
I've just been back under the car and found that the pipes run the full length of the car.
At the front they come out of the tray that they run in (Horizontal) and turn 90 degreed then vanish behind some chassis parts. Does anyone have any ideas of where they go to?
dnsey
- x 19
If the rest of the pipe's sound, it's quite possible to cut out the offending section, flare the end of the rest and fit a 'partial' replacement.
Unless you contemplate doing a lot of Citroen hydraulic work you'll need to go to a Cit specialist who has a flaring tool, but it shouldn't cost much to do - quite possibly less than your time's worth to change the lot.
nigelc116
nigelc116
dnsey
- x 19
He might be right - the original steel pipes can look fairly good but be on their last legs.
It's a pretty straightforward job to replace them though (hardest bit is getting any seized unions undone), and the pipe's cheap, so it shouldn't be too expensive to fix. It's definitely a potential DIY job - remember to bleed the brake caliper when you've finished.
