Hello people,
Thanks for your responses...
Well done anders, i am indeed a diesel head - the car has the td lump in it now as i converted it from 1.8i after crashing my original td zx, engine and gearbox with front subframe was changed, fuel system changed including tank, exhaust swapped and under dash and engine bay wiring looms swapped along with the smaller items like radiator and the whole of the interior becuase the original was blue which i didnt like....
The car has had two new sets of glow plugs, initially some cheapo ones and when that didnt work some NGK's which are meant to be a good brand i think...
- the glow plug relay s working because the interior light goes brighter 20 seconds after light going out.
The leak off pipes from the injectors have been replaced (bosch system you see) along with all under-bonnet flow and return pipes from the pump - right back to the metal ones under the car.........
But it still runs poorly on start up - lots of white smoke it must be air in the system and the only way i can see that happening is if the fuel is draining back to the tank overnight.
Sooty, the car starts on the button and runs smoothly for about 5 seconds before going lumpy and smoky, i think it is starting on residual fuel left in the diesel pump and 5 seconds later or so sucking through some of the air in the fuel line....
Is it possible for air to get in around a faulty seal under the throttle lever on top of thre pump??????
Any ideas - im well chuffed with the car but long for it to run properly on cold mornings
cheers
alastair
Zxtd Aura converted from 1.8i Petrol - Lowered, 20psi boost extra fuel - weeeeeee!
MK2 Cortina 1600e
Honda Acty Romahome - 545cc!! - (the "beast")
