At long last I have cut open a Sphere...
I have cut off the screwed section, and I use this to plug the hole in the rear arm hydraulic rams to prevent crud from entering, when cleaning, ready for the new sphere.
What are they made of?The clear membranes looked perfectly good, but the pressure had still escaped.
The damper disc unit is held in purely by an interference fit, and according to my Dad it is possible to remove it (with considerable difficulty) although I didn't ask how.G4EIY wrote:I did try to remove the damper disks etc from the threaded section, but this was well and truly fixed, and although I gave it some welly, it just would not budge...
Any one managed to do this ?...
More than that, apparently they split a lot more easily than the standard diaphrams, when the gas pressure gets low and the diaphram is forced to start folding back on itself...Clogzz wrote:Translucent membrane, that's the 'multilayer' sphere from the front suspension, with 3 dimples around the plug.
Worth knowing that they can split.
