Be careful with the 2 stroke engine, Make sure the lubrication is looked after because they are wrecked very easily
I done a quote on a Stihl TS 400 disc cutter this week & it was a 2003 machine as well so not that old, Now to do the sort of damage to a Stihl 2 stroke engine that I found takes either loads of abuse of forgetting to use 2 stroke oil in the petrol.
The crank bearings where ruined, There was a few mm of play in them, So much so the flywheel was damaged where it had been hitting the ignition module as it had been spinning.
The piston had smacked the spark plug & closed the gap to nothing & the piston top had started to melt, In fact the piston had got so hot the aluminium it was made out of had changed, It was a different colour & was very brittle.
The cylinder & piston where also badly scored.
The quote for repair was nearly as much as a new machine, The boss of the company whos machine it was came in to see the damage for himself lol
Not a bad picture for a camera phone either
