306 Rear Lights
deere3350
306 Rear Lights
Unread post by deere3350 »
Hi all,
The rear lights on my 306TD are currently giving me a bit of grief. If the indicators are used when the lights are on, the lights go dim. I understand this is caused by a bad earth - can anyone advise how to sort?
Thanks in advance.
PowerLee
Unread post by PowerLee »
Hi
Look at the connector plugs for both rear lights.
Find the yellow & green earth cable in the plugs.
You will find the terminal this cable is connected to is dirty or has a poor connection, Clean them up & make sure they are a tight fit on the pins on the bulb holder.
For a more long term fix you can solder a new earth wire onto the main metal earth part of the lamp holder & then attach the other end to the earth wire on the wiring loom.
You need a good high powered soldering iron to do this, 100 watts would be fine, If you dont own one yourself you could always borrow a friends iron.
You need to do this fix to both rear lights :wink:
deere3350
Thanks for that, Powerlee.
I tried wiggling the connectors a few days ago, but didn't actually think of giving them a good clean. Didn't really expect the connections to deteriorate I suppose :oops:
Will have a go this weekend.
Thanks again for you help.
